EFA 3.0.1.0 Security update released
Important news
Locked
darky83
Site Admin
Post by darky83 »
We would also like to thank everyone for their support and contributions to this project. :clap:
The following issues have been fixed in 3.0.1.0:
Issue #201 Bug - Deprecated release-msg.cgi
Issue #236 Enhancement - Disable spam not delivered messages by default
Issue #253 Bug - EFA-Backup ssl folder
Issue #260 Bug - Header in Apache Settings wrong
Issue #261 Bug - learn-msg.cgi wrong path for sa-learn
Issue #262 Bug - MS_LOGO and MW_LOGO Definitions Needed
Issue #268 Enhancement - EFA-Init link test without DHCP dependency
Issue #269 Bug - SQL error during rename of host name in EFA-Configure
PR #270 Bug - Typo in RELEASENOTES
Issue #272 Security - MailWatch Vulnerability
Please review the RELEASENOTES prior to updating for important information:
https://raw.githubusercontent.com/E-F-A ... LEASENOTES
3) If the update fails for any reason, immediately roll back to snapshot
sudo /usr/local/sbin/EFA-Update -check
continue the update process to 3.0.1.0
if present.
Locked
