How can i delete domain in transport setting ?
Thank
Cyril
Delete domain
Re: Delete domain
Login using putty as admin
Select option 8 - Mail Settings
Select option 4 - Transport settings
Enter the number associated with the domain you wish to delete and then press 'd' to delete the entry.
cyril.lebert
Re: Delete domain
Hello
it's not possible.
Erreur it's not an option............
it's not possible.
Re: Delete domain
Did you add the domain to the postfix config file manually? (I'm just a newbie on EFA.)
Re: Delete domain
Use Webmin and select:
- Server
- Postfix Mail Server
- Transport Mapping
- Server
- Transport Mapping
