I have installed it. What do i need to chage at at my Zimbra to get emails from EFA ?
akhtarmirza
I have installed EFA appliance. What do I need to do at my exchange or Zimbra server to get emails from EFA?
Re: I have installed it. What do i need to chage at at my Zimbra to get emails from EFA ?
https://wiki.efa-project.org/doku.php?i ... #questions
Initial configuration asks for the ip adress of the mailserver, so mails will be transfered to this.
Is this a new mailserver? -> You will need a "connector", which listens on port 25 (SMTP)
Does efa replace an old apliance? -> Probably nothing (maybe reconfigure the connector)
Is it a new infrastructur? -> You will need port redirections at your firewall(s). https://wiki.efa-project.org/doku.php?id=firewall_ports
At MS Exchange it is a "connector", i don't know the name of it in Zimbra.
Maybe https://wiki.zimbra.com/wiki/Incoming_Mail_Problems helps.
