Page 1 of 2
3.0.0.9: SA Learn: WARNING: HOME is not set, using root:
Posted: 13 Apr 2016 06:36
I'm getting the following warning message from the mailwatch interface when I mark messages as spam:
SA Learn: WARNING: HOME is not set, using root: /, Learned tokens from 1 message(s) (1 message(s) examined)
This started happening after I upgraded the system from 3.0.0.8.
Anyone have any ideas where I should add the missing HOME variable and where it should be set?
edit: sa-learn is run by the apache user.
Re: 3.0.0.9: SA Learn: WARNING: HOME is not set, using root:
Posted: 19 Apr 2016 04:36
Anyone have any thoughts? I've not been able to track this down yet.
Posted: 19 Apr 2016 07:31
by DaN
Did you ask the mailwatch guys?
Posted: 27 Apr 2016 08:20
No. I didn't think to try that given that this is an efa installation. I'd think they'd say "the problem is with EFA, now go away."
Can someone help me compare my system with theirs? As root, could you run the following commands and post the results here?
find / -type d -name .spamassassin -exec ls -ld {} \;
my results:
[root@efa /]# find / -type d -name .spamassassin -exec ls -ld {} \;
drwx------ 3 root root 4096 Aug 15 2015 /root/.spamassassin
drwx------ 3 root root 4096 Mar 30 2015 /.spamassassin
Posted: 28 Apr 2016 10:15
drwx------ 3 root root 4096 Nov 29 2014 /.spamassassin
drwx------ 3 root root 4096 Nov 28 2014 /root/.spamassassin
drwxr-xr-x. 2 postfix postfix 4096 Jan 23 2014 /var/www/.spamassassin
Now, sa-learn executes as apache...this is what I have in /etc/passwd:
apache:x:48:48:Apache:/var/www:/sbin/nologin
Posted: 29 Apr 2016 03:09
yes, and when I run the sa-learn command as an apache user id from the command line, I don't get any errors. (I have to change the /etc/passwd file to allow apache to login to test that)
Hmm.. no differences, except I get the error in the web ui and you don't. Weird.
[edit: my files appear the same as yours after all. Not sure how I missed it the first time]
Posted: 10 Jul 2016 18:00
EFA 3.0.0.11 over here, system ahs latest updates installed.
I've just had this exact same problem crop up. I had installed a few new packages today does anything look suspicious?
rpm -qa --qf '%{INSTALLTIME} %-40{NAME} %{INSTALLTIME:date}\n' | sort -n | cut -d' ' -f2-
dkms Sun 10 Jul 2016 11:39:19 CEST
veeamsnap Sun 10 Jul 2016 11:39:22 CEST
fuse-libs Sun 10 Jul 2016 11:42:04 CEST
perl-File-BaseDir Sun 10 Jul 2016 11:42:59 CEST
veeam Sun 10 Jul 2016 11:43:06 CEST
keyutils Sun 10 Jul 2016 11:45:42 CEST
libgssglue Sun 10 Jul 2016 11:45:42 CEST
libtirpc Sun 10 Jul 2016 11:45:42 CEST
nfs-utils-lib Sun 10 Jul 2016 11:45:42 CEST
nfs-utils Sun 10 Jul 2016 11:45:42 CEST
rpcbind Sun 10 Jul 2016 11:45:42 CEST
I removed perl-File-BaseDir which removed 2 other packages and its all back to working now. Anyone see any problems with this?
Removing:
perl-File-BaseDir noarch 0.03-13.el6 @epel 13 k
Removing for dependencies:
perl-File-DesktopEntry noarch 0.08-1.el6 @epel 29 k
perl-File-MimeInfo noarch 0.25-1.el6 @epel 91 k
Posted: 11 Jul 2016 06:28
Weird.
Why did you remove perl-File-BaseDir?
Posted: 11 Jul 2016 06:59
Because I remembered that when I installed some of the other packages from those lists I remember to have seen a notification about some probs with perl-File-BaseDir, hence I had installed it. And seeing that it fixed the problem, it was a good guess.
Still, what to do now? Install it again? Does EFA require it? Why would it break things like it did?
Posted: 11 Jul 2016 07:03
Sorry, I have no idea, but what I am going to do is to remove those packages and see if my error goes away.
If the error does go away, I will try to find out why that package was installed in the first place.
Posted: 11 Jul 2016 07:07
Cool, please give it a try. It would be nice to see if you can confirm this behaviour.
To explain a bit more, I was installing veeam, which is beta and doesn't resolve dependencies automatically, so it gave me a few things it needed like dkms and nfs-utils and while installing those I vaguely remember seeing some problem with perl-File-BaseDir so I installed it only to later see the EFA problems and after a good guess I removed it and things worked again.
Posted: 12 Jul 2016 08:03
Quick question: Are you using the
ole2macro.pm spamassassin module?
I think that may be where the perl-File-BaseDir module came from.
Posted: 12 Jul 2016 08:16
So, I finally got around to testing this. I removed the perl-File-Basedir module with the following command:
[root@efa spamassassin]# yum remove perl-File-BaseDir
Setting up Remove Process
Resolving Dependencies
--> Running transaction check
---> Package perl-File-BaseDir.noarch 0:0.03-13.el6 will be erased
Dependencies Resolved
Package Arch Version Repository Size
Removing:
Transaction Summary
Remove 1 Package(s)
Installed size: 13 k
Is this ok [y/N]: y
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Erasing : perl-File-BaseDir-0.03-13.el6.noarch 1/1
Verifying : perl-File-BaseDir-0.03-13.el6.noarch 1/1
Removed:
Complete!
So only that module was removed. (mimeinfo is still present), and when I train spamassassin, I no longer get those warning messages in the UI. So the problem is solved for me.
Posted: 12 Jul 2016 09:13
Glad to hear your problem is solved. I'm just wondering why I can't install one without the other:
Installing:
perl-File-MimeInfo noarch 0.25-1.el6 epel 54 k
Installing for dependencies:
perl-File-BaseDir noarch 0.03-13.el6 epel 13 k
perl-File-DesktopEntry noarch 0.08-1.el6 epel 22 k
Transaction Summary
Install 3 Package(s)
Posted: 12 Jul 2016 09:47
Try removing perl-File-BaseDir by itself and see if only that can be removed.
As far as I know, File-MimeInfo doesn't actually need it.
Posted: 12 Jul 2016 09:50
*confused*
I tried that above: yum remove perl-File-BaseDir and it removed the mime package too.
Posted: 12 Jul 2016 09:57
That's funny. It didn't for me.
Can you reinstall only perl-File-MimeInfoi? or does it require per-File-BaseDir?
Posted: 12 Jul 2016 10:23
sorry, I realized I didn't copy the entire code. it automatically selects the dependencies
yum install perl-File-MimeInfo
Installing:
Transaction Summary
Posted: 12 Jul 2016 10:44
Sorry ovizil, I've not got an answer.
I suspect the perl File-BaseDir package was installed when I installed File-MimeInfo, but I don't remember.
I was able to remove File-BaseDir, and my File-MimeInfo is gone.
The File-MimeInfo package is not important for EFA unless you are using the ole2macro.pm addition to help check for macro viruses. You will lose some functionality without File-MimeInfo, but not all.
Posted: 12 Jul 2016 11:17
damn, I do use ole2mcro
maybe someone else will come up with an idea.
could you compare your versions of the packages with the ones I posted earlier?
Posted: 12 Jul 2016 11:28
identical packages, versions and repositories.
However, the only perl packages I have installed are
- perl-File-MimeInfo
- perl-File-DesktopEntry
but not
- perl-file-BaseDir
Posted: 12 Jul 2016 11:44
Interesting, perl-File-MimeInfo 0.25-1.el6 requires
perl(File::BaseDir) >
perl(File::DesktopEntry)
https://www.rpmfind.net/linux/RPM/epel/ ... oarch.html
Posted: 12 Jul 2016 12:24
It does and that is the version I have installed. Something must be broken in my dependencies database, because I can see the same thing:
[root@efa spamassassin]# yum deplist perl-File-MimeInfo
Finding dependencies:
* EFA: dl.efa-project.org
* base: ftp.cuhk.edu.hk
* epel: kodeterbuka.beritagar.id
* extras: ftp.cuhk.edu.hk
* rpmforge: mirrors.digipower.vn
* updates: ftp.cuhk.edu.hk
package: perl-File-MimeInfo.noarch 0.25-1.el6
dependency: perl(File::DesktopEntry) >= 0.04
provider: perl-File-DesktopEntry.noarch 0.08-1.el6
provider: perl-File-DesktopEntry.noarch 0.04-1.el6.rf
dependency: /usr/bin/perl
provider: perl.x86_64 4:5.10.1-141.el6_7.1
dependency: perl(Fcntl)
dependency: perl(strict)
dependency: perl(Exporter)
dependency: perl(File::BaseDir) >= 0.03
provider: perl-File-BaseDir.noarch 0.03-13.el6
provider: webmin.noarch 1.770-1
provider: perl-File-BaseDir.noarch 0.03-1.el6.rf
dependency: shared-mime-info
provider: shared-mime-info.x86_64 0.70-6.el6
dependency: perl(Carp)
provider: perl-Devel-Carp.noarch 0.04-1.2.el6.rf
dependency: perl(:MODULE_COMPAT_5.10.1)
dependency: perl(File::Spec)
provider: perl-PathTools.x86_64 3.30-1.el6.rf
provider: perl-File-Spec.x86_64 3.30-1.el6.rf
dependency: perl(bytes)
Interestingly, I have a second package listed
package: perl-File-MimeInfo.noarch 0.15-1.el6.rf
dependency: perl
dependency: perl(File::MimeInfo)
provider: perl-File-MimeInfo.noarch 0.25-1.el6
provider: perl-File-MimeInfo.noarch 0.15-1.el6.rf
which does not have that dependency, and is not installed.
Weird.
Anyway, like I said, according to the notes on ole2macro.pm, having that module is not essential.
Posted: 03 Oct 2017 02:45
Strange. The problem has come back.
I don't know when the problem reappeared as I was not paying attention
I removed the module again, and this time it did take the Mimeinfo module out with it.
[root@efa ~]# yum remove perl-File-BaseDir
--> Processing Dependency: perl(File::BaseDir) >= 0.03 for package: perl-File-DesktopEntry-0.08-1.el6.noarch
--> Processing Dependency: perl(File::BaseDir) for package: perl-File-MimeInfo-0.25-1.el6.noarch
--> Processing Dependency: perl(File::BaseDir) >= 0.03 for package: perl-File-MimeInfo-0.25-1.el6.noarch
---> Package perl-File-DesktopEntry.noarch 0:0.08-1.el6 will be erased
---> Package perl-File-MimeInfo.noarch 0:0.25-1.el6 will be erased
Removing:
Transaction Summary
Remove 3 Package(s)
Installed size: 133 k
Is this ok [y/N]: y
Running Transaction
Erasing : perl-File-MimeInfo-0.25-1.el6.noarch 1/3
Erasing : perl-File-DesktopEntry-0.08-1.el6.noarch 2/3
Erasing : perl-File-BaseDir-0.03-13.el6.noarch 3/3
Verifying : perl-File-BaseDir-0.03-13.el6.noarch 1/3
Verifying : perl-File-MimeInfo-0.25-1.el6.noarch 2/3
Verifying : perl-File-DesktopEntry-0.08-1.el6.noarch 3/3
Removed:
Posted: 03 Oct 2017 14:37
hm, I haven't checked on this in a while and I'm currently on 3.0.2.4 - might upgrade next weekend and report what's what.
