One of my domains is now on another server - different IP
How do I change the iP
Transport settings only allow me to add a Domain !
how do I change IP of Server
Re: how do I change IP of Server
when you see your existing Domains you should see a number before each entry.
Simply enter the corresponding number and you get this choice:
Do you want to [r] replace, [d] delete this entry, or [c] cancel? :
I suggest replace.
You can also edit /etc/postfix/transport and run
postmap /etc/postfix/transport
after.
Regards
akl
I suggest replace.
after.
Regards
akl
