Mail Stuck in MailQueue - Fixed (For Me)
Posted: 24 Mar 2016 10:37
Hi all
I had an issue with mail stuck in mailqueue after upgrade to 3009, after searching through the log I eventually found the issue to be one line in my main.cf file
The upgrade had appended the meta_directory - etc/postfix/ to the same line as the last entry and not on its own line.
fixed the above and all works fine now
