3.0.9 upgrade kdump service fails to start when on-access scanning is enabled
No kdump initial ramdisk found.^[[60G[^[[0;33mWARNING^[[0;39m]^M
Rebuilding /boot/initrd-2.6.32-573.18.1.el6.x86_64kdump.img
No module talpa-vfshook found for kernel 2.6.32-573.18.1.el6.x86_64, aborting.
Failed to run mkdumprd
See: https://www.sophos.com/support/knowledg ... 18455.aspx
The kdump service fails to start. Follow these steps:
Run: cd /lib/modules/`uname -r`
Create a symbolic link to the talpa modules: ln -s /opt/sophos-av/talpa/current/
Search for kernel module dependancies: depmod -a
Restart kdump: /etc/init.d/kdump restart
