Whitelist of Deny Filename
Posted: 22 Mar 2016 09:16
by tabootest
Hi all,
We have enabled Deny Filename = \.zip$ recently for safety reasons. How can we add few exceptions (or whitelist) in order to receive zip files from our customers?
Re: Whitelist of Deny Filename
Posted: 22 Mar 2016 11:27
You can create a ruleset in MailScanner.
If you need help or an example, let me know.
Posted: 22 Mar 2016 23:59
by tabootest
Thanks for reply, plesase kindly provide the syntax requirements and samples of ruleset.
Posted: 23 Mar 2016 11:41
1) Create new rule sets for the zip attachment
Example:
/etc/MailScanner/custom-deny-zips.conf
deny    \.zip$          Deny Zips
(items must be tab separated)
/etc/MailScanner/custom-allow-zips.conf
allow    \.zip$          Allow Zips
2) Create a new rule set for the domains to allow or deny
/etc/MailScanner/custom-ruleset-deny-filenames.conf
From:      example.com      %etc-dir%/custom-allow-zips.conf
From:      default          %etc-dir%/custom-deny-zips.conf
3) Add ruleset to MailScanner
Deny Filenames = %etc-dir%/custom-rulset-deny-filenames.conf
4) Restart MailScanner
Posted: 24 Mar 2016 00:50
by tabootest
Thank you so much.
If we have multiple allowed domains / email addresses, should we put them in separate line as below?
From:	allow@allow.com	%etc-dir%/custom-allow-zips.conf
Posted: 24 Mar 2016 00:59
by ramtech
Wow. That's easier than the way I went about it.
I realise you probably have nothing better to do :? but some more how-tos like this would be so useful for those of us unfamiliar with the syntax for Mailscanner. Having said that, this one gives me some great hints on how to approach other tasks.
Thanks heaps Shawn. :clap:
Posted: 24 Mar 2016 02:04
by tabootest
I tried the configurations but all zip files passed the EFA afterward
Then, I changed /etc/MainScanner/Mailscanner.conf as below
Deny Filenames = %etc-dir%/custom-deny-zips.conf
with /etc/MainScanner/custom-deny-zips.conf
deny	\.zip$	No Zips	No Zips
Items are separated by TAB, but all zip attachments still pass EFA.
Do you have any idea?
Posted: 24 Mar 2016 04:29
by ramtech
tabootest wrote:I tried the configurations but all zip files passed the EFA afterward
I used the above methodology successfully Tabootest. It is stating the bleeding obvious (which you sound like you are well beyond) but you did restart mailscanner after making the changes, didn't you?
Posted: 25 Mar 2016 00:03
by tabootest
After made a change at config files, I restart the service by:
Posted: 25 Mar 2016 02:53
by ramtech
Do all your edits pass a lint test okay?
Posted: 26 Mar 2016 00:41
by tabootest
Sorry, what is a lint test? how to recognize a lint test is ok?
Posted: 28 Mar 2016 23:46
by ramtech
if you go to "Tools/Links" you'll find the LINT tests for SpamAssassin and MailSacnner. They run basically through your configuration and ensure that there are no error essentially. They will display the output on the page that you can then go through and look for any errors and ensure your changes are valid.
I'm not sure why they're called a LINT test in here as LINT was a 'C' Program construct tester. I'm sure there's some logical reason, but I don't know it. Regardless, it is a good testing tool that has saved my bacon a few times with poorly written changes I have made, that it has found for me.
I'm not sure what "correct protocol" is, but i always do them after any changes to config.
Posted: 30 Mar 2016 08:04
by tabootest
Furthermore, how could I only block ZIP files whose size are smaller than 1MB while zipped files with size greater than 1MB are allowed.
