Nice job guys. Looks like it all worked from 3.0.0.8 perfectly.
Unless someone beats me to it, I'll see if I can work up a more detailed "how to replace the certificate" guide - since it identifies as localhost.localdomain, it throws cert errors.
Perhaps it would be possible to integrate LetsEncrypt for 3.0.0.10?
Also, I notice that it's transitioned to HTTPS by default, and works OOTB, but doesn't update the EFA-Configure setting for Apache HTTPS. Suggest after update, people login and run option 11, Y, Y, then install the cert.
3.0.0.9 Update
Re: 3.0.0.9 Update
As for Let's Encrypt, yes, we are looking at it as a possibility.
thermionic
Re: 3.0.0.9 Update
I would love to see letsencrypt integrated
