EFA 3.0.0.9 Released!
Posted: 20 Mar 2016 10:11
We would also like to thank everyone for their support and contributions to this project.
The following issues have been fixed in 3.0.0.9:
Issue #39 Enhancement - Add link for Webmin in MailWatch
Issue #96 Enhancement - Reconfigure to permit regular yum updates
Issue #135 Enhancement - Lots of legit mails blocked on SpamAssassin KAM_BODY_URIBL_PCCC
Issue #148 Enhancement - Allow message view from quarantine reports directly
Issue #162 Enhancement - Upgrade Webmin (to 1.770-1)
Issue #176 Enhancement - Add quarantine cleanup options to EFA-Configure
Issue #179 Enhancement - Get webinterface to work with https by default
Issue #187 Enhancement - EFA service Monitoring
Issue #190 Enhancement - EFA-Init link test
Issue #191 Enhancement - Redirect postfix notifications from postmaster to postmaster email
Issue #192 Enhancement - EFA Update Now option
Issue #193 Enhancement - Removed rpmforge from yum, added EFA repo
Issue #194 Bug - mtalog is empty
Issue #195 Bug - Update EFA hostname in MySQL
Issue #197 Enhancement - Update EFA-Backup for Unbound
Issue #199 Bug - quarantine_report.php issues
Issue #200 Bug - unrar binary not extracting rar files in MailScanner
Issue #203 Bug - Fix Notify Senders sed replace issue in 3.0.0.8
Issue #204 Bug - UTF8 Characters Not Rendering in MailWatch
Issue #211 Bug - MS_LOGO missing
Issue #217 Enhancement - Upgrade Postfix (to 3.0.3)
Issue #219 Bug - Trailing spaces in subjects in MailScanner trigger duplicate subjects in header
Issue #227 Enhancement - Include local.cf in EFA-Backup
Issue #230 Bug - build script not building spamassassin
Issue #233 Bug - Disable postfix utf8 support for now (new feature not compiled in yet)
Issue #238 Enhancement - Upgrade Spamassassin to 3.4.1
Issue #243 Bug - Multiple entries for inet_protocols in main.cf (postfix bumped to 3.0.4)
Issue #244 Bug - Cleanup of SpamAssassin in /usr/local
Issue #245 Bug - ImageCerberus install/move to correct location
Issue #246 Bug - Cleanup old perl modules in /usr/local (and other locations)
Issue #247 Bug - Move GeoIP symlink to new location
Issue #251 Bug - EFA-Backup to /tmp fails when size of backup exceeds size of /tmp
EFA repository is now enabled.
Repoforge repository is now removed.
yum update is now supported with exclusions in place
Please review the RELEASENOTES prior to updating for important information:
https://raw.githubusercontent.com/E-F-A ... LEASENOTES
3) If the update fails for any reason, immediately roll back to snapshot
continue the update process to 3.0.0.9.
if present.
sudo /usr/local/sbin/EFA-Update -check
if present.
