How to disable link tracking
Posted: 16 Mar 2016 22:18
by tpospeshil
I'm being told to disable link tracking so we don't get the messages "MailScanner has detected a possible fraud attempt from ... claiming to be"
How can I do that?
Re: How to disable link tracking
Posted: 17 Mar 2016 12:29
by DaN
Posted: 17 Mar 2016 16:42
by tpospeshil
I searched the forum, but not using Google. Apparently my search skills suck, because I only found info about white-listing sites.
Thanks for your help
Posted: 19 Mar 2016 07:04
google has a better search algorighm than the forum software. It's a useful tip that works on many websites.
Did you find the setting you need?
Posted: 19 Mar 2016 23:06
by tpospeshil
Yes, I'm good to go. Thanks
