EFA-Backup and official certificate, suggested improvement for EFA-Backup
jokr
Post by jokr »
Hi !
I had to install an offical ssl certificate for postfix in /etc/postfix ssl/.
This certificate does not reside in the file smtpd.pem, but in some files with other names.
In EFA-BAckup.log there are messages like this
[EFA] Good you are root
Beginning System Backup at 03112016 034201
cp: cannot stat `/etc/postfix/ssl/smtpd.pem': No such file or directory
Backup Completed at 03112016 034201
Purging Backups older than 5...
Old backups purged.
Looking at the code of EFA-Backup, EFA-Backup wants to backup /etc/postfix/ssl/smtpd.pem
May be this should be impoved to backup the whole directory /etc/postfix/ssl/* ?
