How to enable SPF?
Posted: 11 Mar 2016 15:07
by martinwa
SPF - checking the sender is using the right IP for the domain.
How do I enable that the easy way?
It can be done in, ClavAV, postfix and spamassassin as I can see.
Best regards
Martin
Re: How to enable SPF?
Posted: 12 Mar 2016 14:58
Depends on whether you want the emails to show up in your reports...
If you do it in postfix, postfix will block it during the connection phase if it fails SPF check, and you won't get a report in MailScanner.
If you use spamassassin or clam, you can assign a score for SPF checks, and it will show up in MailScanner reports.
Posted: 19 Oct 2017 19:44
by andreshko.georgiev
How can I enable SPF check in SpamAssassin?
Posted: 20 Oct 2017 21:48
Posted: 18 Apr 2023 13:04
by Pro100i
Good afternoon, can you tell me how to enable checking spf at the postfix. So that those domains that do not have any spf record discard e-mails
like this one spf=none smtp.mailfrom=inbox.org
