Customize quarantine report
Posted: 07 Mar 2016 08:51
by akl
Hi All,
can someone tell me where to find the template for the weekly quarantine Report?
I want to customize that.
Does anyone know wether it is possible to create the Report on a daily Basis?
Thanks in advance
akl
Re: Customize quarantine report
Posted: 07 Mar 2016 10:24
by akl
ok, maybe my "call for help" was a Little quick, but maybe somebody is interested too.
I found out, that the quarantine report is most likely created by the script /usr/local/bin/mailwatch/Tools/Cron_jobs/quarantine_report.php
What I don't understand is, that this script is executed by /etc/cron.daily/mailwatch
#!/bin/bash
/usr/local/bin/mailwatch/tools/Cron_jobs/db_clean.php >> /dev/null 2>&1
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_maint.php --clean >> /dev/null 2>&1
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php >> /dev/null 2>&1
Doesnt that mean it is already a daily task?
I don'nt know any php....I wonder where the $required_constant array is passed to quarantine_report.php
I am interested in the QUARANTINE_REPORT_DAYS variable....
Also, what I don't understand is the part
In the last %s day(s) you have received %s e-mails that have
I understand %s as a variable. It is referenced as days and the amount of mails received....?
Shouldnt that read somewhat %s days you have received %m Mails....
Time to buy a PHP-book?
Cheers
akl
