error when running quarantine_report.php
Posted: 26 Feb 2016 13:42
I have tried running the quarantine report manually,
I believe the command is?
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php
I see the error
Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 263
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 948
I see the error
