Hi there
Would it be possible to create some kind of rule to make a catchall for a certain domain which then sends it trough the filter to for example info@domain.com?
Kind regards,
Justin
Catchall records
Re: Catchall records
I believe postfix has this feature...not sure about the details, though.
Any idea if this is do-able to integrate it into EFA?shawniverson wrote:I believe postfix has this feature...not sure about the details, though.
Could it be possible to integrate it?shawniverson wrote:I believe postfix has this feature...not sure about the details, though.
Something like this: http://www.cyberciti.biz/faq/howto-setu ... -accounts/
