Outgoing SMTP
Posted: 10 Feb 2016 10:37
by Justin
Hi there,
Is there a possibility to let efa-project send mail from an exchange server, with authentication?
Kind regards,
Justin
Re: Outgoing SMTP
Posted: 10 Feb 2016 22:42
Yeah you can set up SASL Auth on the Submission port in Postfix...
Re: Outgoing SMTP
Posted: 10 Feb 2016 23:59
by Justin
shawniverson wrote:Yeah you can set up SASL Auth on the Submission port in Postfix...
Is it also possible to make an authenticated mail relay of EFA? We don't want to open our Exchange server for mail relaying due too security
Re: Outgoing SMTP
Posted: 11 Feb 2016 22:41
Yes
Re: Outgoing SMTP
Posted: 24 Feb 2016 18:08
by preed88
I have a question on this topic as well. I have EFA set to filter incoming and outgoing messages to and from my Exchange server. I have a blacklisted IP from Comcast, so I cannot send mail directly to other users. My mail goes through SendGrid, which requires authorization to relay mail, but I saw no option to configure the credentials. Do I need to dive into Postfix conf files to configure this?
Re: Outgoing SMTP
Posted: 28 Feb 2016 16:23
by preed88
Any help?
Re: Outgoing SMTP
Posted: 28 Feb 2016 18:33
by Zwabber
Use Webmin and go to the Postfix mail server. Open "SMTP Authentication And Encryption" and fill in the credentials needed.
