Zip file Block
Posted: 08 Feb 2016 15:52
by itr
im using
Deny Filenames = \.zip$ in the Mailscanner.conf for blocking all zip files.
But is it possible to block all zip files except the files starting with (for example): ITR_*.zip?
Thank you
Re: Zip file Block
Posted: 08 Feb 2016 23:35
That's a tough one.
You don't want to block basically "ITR_*\.zip$", so if you inverse that it with allow everything else (including zips).
So, you will need to use the rulesets instead.
How about this?
/etc/MailScanner/filename.rules.conf (use tabs between not spaces)
allow	ITR_*\.zip$	Allow zips with ITR Prefix	Allow zips with ITR Prefix
#allow	\.zip$	-	-
deny	\.zip$	Deny zips	Deny zips
Re: Zip file Block
Posted: 09 Feb 2016 06:52
by itr
thank you for the answer.
Its now blocking the zip files with the new "Deny zips" message, but when sending it with prefix ITR_Test.zip its also blocked via the "Deny zips" rule.
Is the deny rule "higher" then the allow rule?
Got another idea? ;)
Thank you!
Re: Zip file Block
Posted: 10 Feb 2016 22:40
Dang, block overrides allow...
What about this?
deny	(?!ITR_)\.zip$	Deny zips	Deny zips except for those with ITR prefix
Re: Zip file Block
Posted: 15 Feb 2016 20:14
by itr
mhm comes up with the new error message "Deny zips except for those with ITR prefix" but it is blocking files like "ITR_523.zip"
Thank you
Re: Zip file Block
Posted: 15 Feb 2016 22:10
Forgot a wildcard...try this....
deny   (?!ITR_).*\.zip$   Deny zips   Deny zips except for those with ITR prefix
Re: Zip file Block
Posted: 16 Feb 2016 10:22
by itr
mhm the same "problem" it blocks all zip files :(
Thx
Re: Zip file Block
Posted: 16 Feb 2016 11:14
deny   ^(?!ITR_).*\.zip$   Deny zips   Deny zips except for those with ITR prefix
Re: Zip file Block
Posted: 16 Feb 2016 17:00
by itr
thank you very much, this is working :)
Thank you!
Re: Zip file Block
Posted: 25 Feb 2016 11:15
by itr
another question ;)
is it possible to notify the sender AND the receiver that a zip was blocked? Also is there an option to just set *.zip to a score that it gets blocked and could be released via the Link that is sent from EFA3?
Thx
