3.0.08 ClamAV updates fail
Posted: 05 Feb 2016 14:05
I downloaded the latest Hyper-V-package (Version 3.0.0.8) and ran through the setup "wizard".
After that I connected to the webmin page and installed over 200 package updates. These updates have been finished successfully except for:
- clamav - Anti-virus software - New version 0.99-3.el6
- clamav-db - Virus database for clamav - New version 0.99-3.el6
- clamd - The Clam AntiVirus Daemon - New version 0.99-3.el6
These packages fail with the following error:
Do you have any ideas what I could do?
Thank you!
Best regards,
dwmp
Whatever I do, the updates fail (I tried updating webmin version first, install updates individually, rebooting... I even downloaded the complete EFA package again and set it up again but still no success)Building complete list of updates ..
Now updating clamav ..
Installing package(s) with command /usr/bin/yum -y install clamav ..
Setting up Install Process
* base: mirror.i3d.net
* epel: mirrors.n-ix.net
* extras: centos.mirror1.spango.com
* rpmforge: mirror.de.leaseweb.net
* updates: mirror.cj2.nl
Resolving Dependencies
--> Running transaction check
---> Package clamav.x86_64 0:0.98.7-1.el6 will be updated
--> Processing Dependency: libclamav.so.6()(64bit) for package: clamd-0.98.7-1.el6.x86_64
--> Processing Dependency: libclamav.so.6()(64bit) for package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64
--> Processing Dependency: libclamav.so.6(CLAMAV_PRIVATE)(64bit) for package: clamd-0.98.7-1.el6.x86_64
--> Processing Dependency: libclamav.so.6(CLAMAV_PUBLIC)(64bit) for package: clamd-0.98.7-1.el6.x86_64
--> Processing Dependency: libclamav.so.6(CLAMAV_PUBLIC)(64bit) for package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64
--> Processing Dependency: clamav = 0.98.7-1.el6 for package: clamd-0.98.7-1.el6.x86_64
---> Package clamav.x86_64 0:0.99-3.el6 will be an update
--> Processing Dependency: clamav-db = 0.99-3.el6 for package: clamav-0.99-3.el6.x86_64
---> Package clamav-db.x86_64 0:0.98.7-1.el6 will be updated
---> Package clamav-db.x86_64 0:0.99-3.el6 will be an update
---> Package clamd.x86_64 0:0.98.7-1.el6 will be updated
---> Package clamd.x86_64 0:0.99-3.el6 will be an update
Error: Package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64 (@rpmforge)
Requires: libclamav.so.6()(64bit)
Removing: clamav-0.98.7-1.el6.x86_64 (@epel)
Updated By: clamav-0.99-3.el6.x86_64 (epel)
Not found
Available: clamav-0.96.4-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.96.5-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.1-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.2-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.3-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.4-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.5-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.5-2.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.6-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.7-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98-2.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.1-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.3-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.4-1.el6.rf.x86_64 (rpmforge)
Requires: libclamav.so.6(CLAMAV_PUBLIC)(64bit)
Not found
.. install failed!
Now updating clamav-db ..
Installing package(s) with command /usr/bin/yum -y install clamav-db ..
--> Processing Dependency: clamav-db = 0.98.7-1.el6 for package: clamav-0.98.7-1.el6.x86_64
Not found
Not found
.. install failed!
Now updating clamd ..
Installing package(s) with command /usr/bin/yum -y install clamd ..
--> Processing Dependency: clamav = 0.99-3.el6 for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7(CLAMAV_PUBLIC)(64bit) for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7(CLAMAV_PRIVATE)(64bit) for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7()(64bit) for package: clamd-0.99-3.el6.x86_64
Not found
Not found
.. install failed!
Thank you!
Best regards,
dwmp
