How to disable kam.cf
Posted: 01 Feb 2016 23:12
by toddh
The kam.cf file is causing a lot of FPs and we would like to disable it. I dont see it in the mailscanner or spamassassin config files, but adminitatly I may not be looking in the correct spot.
Can someone tell me how to disable this so that it is not run. Also how to remove it so that the file is not downloaded/updated in the future.
Thanks,
Todd
Re: How to disable kam.cf
Posted: 02 Feb 2016 09:41
by DaN
nothing here
Posted: 03 Feb 2016 11:15
You can disable kam...
1) Remove KAM.cf from /etc/mail/spamassassin
2) edit /etc/cron.daily/EFA-Daily-cron and comment out the following line:
#/usr/local/sbin/EFA-SA-Update -cron >> /var/log/EFA/EFA-SA-Update.log 2>&1
Note that future updates may revert this change.
Posted: 04 Feb 2016 17:20
by toddh
Thanks Shawn.
I added an exception to the local.cf for the kam_address that was triggering a high number of FPs. We may go further and totally disable the kam.cf. It contains references to Houston high rise building that contain hundreds of business. In it's current state kam.cf is adding weight 2x the Hold for legitimate address listings that are entirely too generic.
We contacted the author Kevin A. McGrail but had gotten no response in several days.
Todd
Posted: 05 Jul 2016 19:12
Just wanted to add that inside: /usr/local/sbin/EFA-SA-Update I see the download URL:
http://www.peregrinehw.com/downloads/Sp ... rib/KAM.cf which seems to then redirect to
https://www.pccc.com/downloads/SpamAssa ... rib/KAM.cf so I guess that should be updated in a future EFA version.
The original URL returns: Status: HTTP/1.1 301 Moved Permanently
Posted: 06 Jul 2016 22:35
Posted: 14 Apr 2017 11:59
by kmcgrail
All,
I came across this forum recently and noted the complaint about KAM.cf. We are typically very responsive about FPs so it must have been overlooked.
And yes, I believe we found the issue with the address rule many moons ago so would love to hear about current FPs.
As noted in the cf file,
https://raptor.pccc.com/raptor.cgim?tem ... rt_problem is the best way to reach us especially since emailing about spam issues can run afoul of filters, etc.
I'm glad you find the work useful. We are quite proud of it and love supporting open source project to stop bastard spammers.
Regards,
Kevin A. McGrail (aka KAM)
Apache SpamAssassin Chair Emeritus
Posted: 15 Apr 2017 21:15
kmcgrail wrote: 14 Apr 2017 11:59
Regards,
Greetings and thank you for your kind words and support!
