Mail suggested to be spam: Notify sender, not receipient
SPQRInc
Post by SPQRInc »
let's assume that there is a mail sent from
sender@abc.com
to
recipient@xyz.com
The mail is rated as spam - now the recipient gets an mail like this one:
If you are satisfied that this message is not spam, you can release it from quarantine
by clicking http://example.com/cgi-bin/release-msg. ... 574ce6a45e
Well, how can I change this behavior? I would like to inform the sender, that his mail was not delivered - not the recipient.
Re: Mail suggested to be spam: Notify sender, not receipient
You can turn off the message for the recipient in EFA-Configure under Spam Settings.
I don't recommend notifying the sender because this gives away your spam making decisions to spammers, and it can cause serious backscatter when your domain is targeted from spoofed addresses.
