Hi all,
Is there a best practice how to keep your system up to date?
Should I run yum (whit exceptions) on a regular basis or should I wait for updates to EFA, if i run EFA-Update it only checks for latest version of EFA and not the updated packages.
Any thoughts?
/Lennart
update best practice
Re: update best practice
At this point I would wait. 3.0.0.9 will fully support yum update with exceptions defined internally, to make updating easier in combination with EFA-Update.
Do you know when EFA 3.0.0.9 update is planned?shawniverson wrote:At this point I would wait. 3.0.0.9 will fully support yum update with exceptions defined internally, to make updating easier in combination with EFA-Update.
Kind regards,
Heronimus
beta is being readied for this week. After a week of testing for last minute issues, it will move into release.
