Hi there,
there is ticket system, which send us emails from random accounts:
rvs=785af2572=no.reply@bmw.com
So i want to add *@xyz.com and default@xyz.com - but it doesn't work.
Anyone an idea?
*@domain for whitelist
- 2015-12-16 14_34_31-Mailwatch for Mailscanner - Whitelist_Blacklist.jpg (36.77 KiB) Viewed 5642 times
Re: *@domain for whitelist
did you read
viewtopic.php?t=704
viewtopic.php?t=1260
OR
viewtopic.php?t=871 ?
The forum search function is crap, use instead a external search engine.
For example go0gle:
site:forum.efa-project.org whitelist domain
did you read
viewtopic.php?t=704
OR
For example go0gle:
Hey mate
Did you find a way to fix this problem??
Yes. Do it like this:alchemist wrote:Hey mate
- 2016-05-23 09_38_22-MailWatch for Mailscanner - Whitelist_Blacklist.png (6.87 KiB) Viewed 5447 times
