Change URL for release it from quarantine
pawell
Post by pawell » 10 Dec 2015 14:39
Hi there,
i want to change the url, add https:// and a port:
http://spamfighter.bahh.local/cgi-bin/r ... 703d30c863
to
https://differentipadress:22222/cgi-bin/release-msg.cgi?datenumber=20151209&id=4A4651201BF.A02F1&token=b3c9be79533f1c908d72b4703d30c863
I have the following scenario:
Public IP Adress of the router > Port forwarding on 22222 to the EFA Server > Gateway for the email clients > Client
The Client's can not access to the EFA Server - only via internet.
Our UCE (spam) detectors have been triggered by a message you received:-
From: bounce_prefix-1449661048.113.morjklcluriw@geld-zuhause-verdienen.xyz
Subject: 1400 Euro von zu Hause aus verdienen
Date: Wed Dec 9 18:41:07 2015
This message has not been delivered. The detectors that were triggered are spam, SpamAssassin.
The message to you has been detected as spam based on either its contents or the mail server which sent the message to us, or both.
If you have any questions about this, or you believe you have received this message in error, please contact the site system administrators.
Your system administrators will need the following information:
Server name: spamfighter.bahh.local
Message id: 4A4651201BF.A02F1
Date code: 20151209
If you are satisfied that this message is not spam, you can release it from quarantine by clicking http://spamfighter.bahh.local/cgi-bin/r ... 703d30c863
Note that if this mail has been send to multiple recipients you will release this mail to all users.
Company
http://www.efa-project.org
DaN
Re: Change URL for release it from quarantine
Post by DaN » 14 Dec 2015 12:58
Hallo
did you check https://efa-project.org/w/index.php?tit ... %28menu%29 "11)"? "Apache Settings - Configure Apache - Enable port 443? (y/N)"
The port forwarding from https (443) to 22222 (https://differentipadress:22222/cgi-bin/release-msg.cgi) should not be a problem.
See viewtopic.php?t=217 too.
pawell
Post by pawell » 15 Dec 2015 08:58
DaN wrote:Hallo
I've edited the /etc/MailScanner/reports/recipient.spam.report.txt
That worked for me.
Thanks - closed
