Backup whitelists etc
Justin
Post by Justin »
Hi there,
I would like to know which of the files i need to backup to recover, may it ever crash.
Had this before, and the whole whitelist needed to recreate itself but i would like to import the existing one.
This would also be very usefull when building an extra spamfilter next to it, or recover from a crash.
I guess the database also needs to be taken in the backup.
Re: Backup whitelists etc
Take a look at /var/EFA/backup
Already done for you :) Just grab the backup files
Sean,
What is the purpose for this backup file? Is it supposed to include all the local configuration files?
If so, then could you include /etc/mail/spamassassin/local.cf?
pdwalker wrote:Sean,
That is correct.
pdwalker wrote: If so, then could you include /etc/mail/spamassassin/local.cf?
Will do.
