Is there a way to give an extra score (for example +2) to all messages that come with spf fail and have a speficic domain ?
I have in SPF for my domain non only my mailserver but also other mailservers that are listed in spf
I want that all messages that come to me from mailserver not in my spf have an extra score because are more probably spam instead other that can be from a mistake of Others
blacklist_from_not_spf ?
Re: blacklist_from_not_spf ?
I am not sure that problem was eplained correctly, perhaps is my english that is not good
I use EFA sending email from domain gruppocomet.it
In SPF gruppocomet.it is authorized to EFAs IP and other external IP that are our external services
So EFA receives messages from gruppocomet.it that come from these services and that take spf ok and that are whitelisted_from_spf
But I want to add score to messages that come from gruppocomet.it with spf fail !!! because i am sure of how i write my spf and i cant be so sure about others spf
SOLVED
I write a custom rule so :
# Regola per dare uno score a chi manda mail coi nostri domini da un server non in spf
describe MYDOMAIN_D Dominio locale
header MYDOMAIN_D From =~ /(comet\.it|gruppocomet\.it|vignuda\.it|marinipandolfi\.it|agenti\.gruppocomet\.it|sime\.gruppocomet\.it)/
score MYDOMAIN_D -0.01
meta SPF_FAIL_MYDOMAIN ( MYDOMAIN_D && SPF_FAIL )
describe SPF_FAIL_MYDOMAIN Spf fallito su Dominio locale
score SPF_FAIL_MYDOMAIN 8.00
This looks pretty cool. So does this say that if it matches your domain and the SPF check fails it is spam? So, those with a valid SPF record can detect when mail is not from them via the SPF record?
For example i have this spf :
MYDOMAIN +ip1 +ip2 +ip3 -all
ip1 is efa, and this is not relevant
ip2 and ip3 are internet mail server associates to mass mailing or web services that send mail using MYDOMAIN
when efa receive mail from MYDOMAIN it accept only ip2 and ip3 it Others spoof MYDOMAIN adn sent it to efa they get 8.00 score
Hi There
I like this rule and would like to use it with my Setup.
Where do i add this rule?
Must i add it manually somwhere?
anywhere in local.cf file
