FREEMAIL_FORGED_REPLYTO
twstevensuk
Post by twstevensuk »
Where can i change this? i have checked in Kam.cf but cannot find it in their?
i can see the score is 2.0 and need to increase this
Re: FREEMAIL_FORGED_REPLYTO
[root@efa ~]# cd /var/lib/spamassassin/
[root@efa spamassassin]# grep -R FREEMAIL_FORGED_REPLYTO *
3.004000/updates_spamassassin_org/30_text_pt_br.cf:lang pt_BR describe FREEMAIL_FORGED_REPLYTO Email gratuito usado no Reply-To, mas n▒o no From:
3.004000/updates_spamassassin_org/50_scores.cf:score FREEMAIL_FORGED_REPLYTO 1.199 2.503 1.204 2.095
3.004000/updates_spamassassin_org/20_freemail.cf:meta     FREEMAIL_FORGED_REPLYTO  __freemail_hdr_replyto && !FREEMAIL_FROM && !__freemail_safe
3.004000/updates_spamassassin_org/20_freemail.cf:describe FREEMAIL_FORGED_REPLYTO  Freemail in Reply-To, but not From
3.004000/updates_spamassassin_org/20_freemail.cf:score    FREEMAIL_FORGED_REPLYTO  0.1
So that's where the rule is, now what does it mean and how do you change it?
Customizing spamassassin scores
I don't know what the line from 50_scores.cf means. Perhaps someone else can explain what the 4 numbers are for. Otherwise, I'd just try modifing the local.cf to adjust the FREEMAIL_FORGED_REPLYTO spamassassin score.
Good luck!
twstevensuk
Thanks, The issue is that i cannot see this option in /etc/mail/spamassain/local.cf ?
Below is my local.cf file
# This is the right place to customize your installation of SpamAssassin.
# See 'perldoc Mail::SpamAssassin::Conf' for details of what can be
# tweaked.
# Only a small subset of options are listed below
# Add *****SPAM***** to the Subject header of spam e-mails
# rewrite_header Subject *****SPAM*****
# Save spam messages as a message/rfc822 MIME attachment instead of
# modifying the original message (0: off, 2: use text/plain instead)
# report_safe 1
# Set which networks or hosts are considered 'trusted' by your mail
# server (i.e. not spammers)
# trusted_networks 212.17.35.
# Set file-locking method (flock is not safe over NFS, but is faster)
# lock_method flock
# Set the threshold at which a message is considered spam (default: 5.0)
# required_score 5.0
# Use Bayesian classifier (default: 1)
# use_bayes 1
# Bayesian classifier auto-learning (default: 1)
# bayes_auto_learn 1
# Set headers which may provide inappropriate cues to the Bayesian
# classifier
# bayes_ignore_header X-Bogosity
# bayes_ignore_header X-Spam-Flag
# bayes_ignore_header X-Spam-Status
# Some shortcircuiting, if the plugin is enabled
ifplugin Mail::SpamAssassin::Plugin::Shortcircuit
# default: strongly-whitelisted mails are *really* whitelisted now, if the
# shortcircuiting plugin is active, causing early exit to save CPU load.
# Uncomment to turn this on
# shortcircuit USER_IN_WHITELIST on
# shortcircuit USER_IN_DEF_WHITELIST on
# shortcircuit USER_IN_ALL_SPAM_TO on
# shortcircuit SUBJECT_IN_WHITELIST on
# the opposite; blacklisted mails can also save CPU
# shortcircuit USER_IN_BLACKLIST on
# shortcircuit USER_IN_BLACKLIST_TO on
# shortcircuit SUBJECT_IN_BLACKLIST on
# if you have taken the time to correctly specify your "trusted_networks",
# this is another good way to save CPU
# shortcircuit ALL_TRUSTED on
# and a well-trained bayes DB can save running rules, too
# shortcircuit BAYES_99 spam
# shortcircuit BAYES_00 ham
endif # Mail::SpamAssassin::Plugin::Shortcircuit
Because you have to add it into your local.cf file yourself.
score FREEMAIL_FORGED_REPLYTO 4.0
You can score it more or less according to your preference.
Qlink
Post by Qlink »
hi guys,
i've also tried to raise the score for FREEMAIL_FORGED_REPLYTO, but it seems like it doesn't work.
EFA still uses the old score.
i've added the line at the end in /etc/mail/spamassain/local.cf:
# use_bayes 1
#   classifier
#   Whether to decode non- UTF-8 and non-ASCII textual parts and recode
#   them to UTF-8 before the text is given over to rules processing.
# normalize_charset 1
but efa still uses 2.10 score:
Spam Report:
Score	Matching Rule	Description
-7.61	AWL	Adjusted score from AWL reputation of From: address
0.80	BAYES_50	Bayes spam probability is 40 to 60%
2.10	FREEMAIL_FORGED_REPLYTO	Freemail in Reply-To, but not From
1.00	HK_RANDOM_REPLYTO
16.00	KAM_SEX_EXPLICIT	Subject or body indicates Sexually Explicit material
0.00	SPF_FAIL	SPF: sender does not match SPF record (fail)
0.00	SPF_HELO_NONE	SPF: HELO does not publish an SPF Record
am i doing something wrong ?
Qlink
Post by Qlink »
no one here who can help me in this case ?
a lot of spam mails with FREEMAIL_FORGED_REPLYTO are getting through EFA because of this non working rule :(
thanks in advance
score FREEMAIL_FORGED_REPLYTO 4.0      <<<  move this line outside of the if/endif blocks as you created a dependency on the Shortcircuit plugin
To Check if the Shortcircuit plugin is active or not
/etc/mail/spamassassin/v320.pre
Remove the '#' if you want to activate the plugin
