Mailscanner double filename extension
DaN
Post by DaN »
see viewtopic.php?f=5&t=1178
Junk mail with unwanted attachments have mostly blank characters between the filename extensions.
Either the rule is adjusted or it should be commented out.
Just a suggestion.
darky83
Site Admin
Re: Mailscanner double filename extension
Post by darky83 »
It might be worth a little discussion.
the original intend of the double filename check from the mailscanner devs is to block off files like:
- file.zip.exe
- file.zip.com
- file.zip.scr
- file.docx.exe
etc..
This rule causes some problems for users, as the default also hits on items like:
- file.v01.docx
- file.zip.zip
- file.v01.zip
etc.
The current line says:
deny    \.[a-z][a-z0-9]{2,3}\s*\.[a-z0-9]{3}$   Found possible filename hiding                          Attempt to hide real filename extension
Might be an idea to change it so that only files with double file extensions that end with .exe, .com or .scr (or maybe even some more) are blocked.
So something like:
.[a-z][a-z0-9]{2,3}\s*\.(exe|scr|bat|com)$
That will only check double file extensions that end with .exe, .scr or .bat or .com
Thoughts?
Not a bad idea. Handle all the "executable" extensions (there are many) and you've handled the main problem we are trying to solve.
darky83
Site Admin
Post by darky83 »
Okay,
lets create a list to try to identify them all:
- .exe
- .com
- .scr
- .vbs
- .bat
- .pif
- .msi
- .hta
- .vb
- .ws
- .wsf
- .ps1
I am sure i'm missing some here :)
skoppes
Post by skoppes »
How about .js as well, if this double-extension includes looking inside of non-password zip attachments.
We're getting slammed with .zip files containing malicious .doc.js malware downloader files, but EFA is letting a good portion of them right through. Not sure what to do about this.
zohman
Post by zohman »
darky83 wrote: So something like:
Thoughts?
Thank you,
i disabled also the default line as i encounter problems with it,
but i dont see any reason to make line like this Darky, .exe .bat etc, will be deny from the first place..
no matter of the right side of the file name.
so it cant be "pretending", it can only take more throughput during the scanning process.
this is ment to be exactly what it is "Deny all other double file extensions", if you want to block extention deny it like:
deny	\.exe$	Windows/DOS Executable           Executable DOS/Windows programs are dangerous in email
Great Day to you all.
Thx for info! Sounds like we just need to abandon double file name extension checking and focus on real extensions, imo.
darky83
Site Admin
Post by darky83 »
Not alway's
Some want to allow .exe etc.. so need to think about that also :)
