how can I change the SpamAssassin score?
I need to change URIBL_DBL_SPAM
						change SpamAssassin score
				massimo.rc
Re: change SpamAssassin score
and I need to change ALL_TRUSTED
Please help me
						Please help me
Did you read viewtopic.php?f=14&t=814&p=2612&hilit=local.cf#p2612?
Or viewtopic.php?f=14&t=1088&p=3580&hilit=score#p3580?
Or viewtopic.php?f=13&t=827&p=3252&hilit=score#p3252?
There are more posts about the topic, but the conclusion is
add a rule to /etc/mail/spamassassin/local.cf
https://wiki.apache.org/spamassassin/WritingRules
				massimo.rc
Ok,
I've see the post.
But I've write
score ALL_TRUSTED 0.1
in /etc/mail/spamassassin/local.cf and I sent a mail.
In see the Spam Report in EFA but the score did not change. Has remained the same: -1.0
Have you any suggestions?
						I've see the post.
But I've write
With the words of darky
Does it work?
spamassassin is invoked by mailscanner at each mail, so guessing that the config is re-read everytime.
But might be that the config is cached somewhere, so if it is not working just reload the MailScanner service.-
				massimo.rc
Ok,
thanks.
Now works.
						thanks.
Now works.
