How to receive to postmaster@[IP_ADDRESS]
authierma
Post by authierma »
Probably this question has been asked often but I cannot seem to find the right answer.
After checking with dnsquerries.com (smtp), it seems no e-mail can be sent to postmaster@[IP_ADDRESS]
What setting in EFA must be modified so my installation be compliant?
ref: The SMTP server does not accept mails to postmaster@[IP_ADDRESS]. This is a very bad thing, as this address is used by people that don't know your domain name! The reported error is
Marc
darky83
Site Admin
Re: How to receive to postmaster@[IP_ADDRESS]
Post by darky83 »
Why would you want to receive mail on user@IP
This is not supported anywhere and should never be used.
a long long long time ago (the beginning of the internet..) this was used but now with multi domain servers its useless and is not supported anymore.
authierma
Post by authierma »
Sorry, here's the complete error message:
Accepts Mail to domain literals The SMTP server does not accept mails to postmaster@[IP_ADDRESS]. This is a very bad thing, as this address is used by people that don't know your domain name! The reported error is:
554 5.7.1 <postmaster@[x.x.x.x]>: Relay access denied
Ref: http://www.dnsqueries.com/en/smtp_test_check.php
Maybe try it with your own e-mail server info.
Thanks,
Marc
darky83
Site Admin
Post by darky83 »
As mentioned, there is no need to allow this and it is not supported in E.F.A.
it is old, unused, and an overall bad practice.
