32 bit support
i_like_penguins
32 bit support
Will EFA run on a 32 bit CPU? Looking at the net install script, it points to x86_64 for the install source, but after that I don't see any specific refrences to packages that would be 64 bit only.
Re: 32 bit support
It should work but we build everything on 64bit, we don't see any reason to also provide an 32bit build.
As the systems requires a minimum of 4GB memory and for a larger install even more, using 32bit would be useless.
i_like_penguins
Re: 32 bit support
I have an old hp dl380 g3 sitting around with 6gb of ram in it. I might try it this weekend and see what happens. I am not sure I would be able to toss enough traffic at it to create a valid test though. Sounds like a fun drinking project.
i_like_penguins
Re: 32 bit support
I finally got around to testing this, and yes, 32 bit works. I copied the kickstart script to a local web server and modified it to use the 32 bit repo. After that everything worked as expected. I really don't know how well it handles load though. I only get a dozen or so spam emails a day, so I don't have a good way to test it.
