Edit default settings
Justin
Post by Justin »
Hi everyone,
I have a few questions:
1. Is it possible to edit the defaut messages?
For example:
{Spam not deliverd} (and it's content)
Mail delivery failed: returning message to sender (and it's content)
2. Is this possible to change the EFA logos?
3. Force MailScanner page on HTTPS, just like Webmin
Kind regards,
Justin
Re: Edit default settings
1. Yes. Use EFA-Configure to change this behavior under Spam Settings
2. Yes. Logos are in /var/www/html/mailscanner/images
3. Yes Use EFA-Configure to enable HTTPS under Apache Settings
Justin
Post by Justin »
shawniverson wrote:1. Yes. Use EFA-Configure to change this behavior under Spam Settings
1. It asks me too enable two settings, nothing more. Where do i edit the text?
2. Thank you
3. Thank you, will check this out
darky83
Site Admin
Post by darky83 »
See the files in
/etc/MailScanner/reports/
Note that if you make manual changes these might be overwritten by an next update, so always document the changes you made.
Justin
Post by Justin »
darky83 wrote:See the files in
Thank you! Will check this out tommorow
