3.0.0.7 to 3.0.0.8 update FAIL
mshanley
Post by mshanley »
Ran the update, it upgraded the kernel. Rebooted ran the update again, it downloaded a bunch of stuff then FAILS on MD5 Checksum and then aborts. (Md5 Checksum does not match! Aborting....)
I tried it 2 times same result :(
Re: 3.0.0.7 to 3.0.0.8 update FAIL
Md5 must match to continue upgrade. This is a download integrity measure.
8fc17bb08a236bdf34b85dca72aea661 EFA-Update-3.0.0.7-3.0.0.8.tar.gz
If it does not, your update file is getting altered in transit or is only a partial download. Make sure there are no proxies or filters between you and the download site, http://dl.efa-project.org
mshanley
Post by mshanley »
I run a Linux based Firewall I have for 10 years... called Untangle.. im not taking it out now.
Upgrades have been working fine for the last year.
I will turn off The AV scanner and see if that is it...
Looks like it's working now..
woundride
Post by woundride »
To resolve this problem, I've downloaded the file at this address : http://dl.efa-project.org/update/EFA-Up ... 0.8.tar.gz with Firefox and I've pushed the file in the directory /tmp/EFA-Staging with Winscp at 99% of download on EFA...
It's not academic, but it work !
Best regards.
Charles.
The_Penguin
Post by The_Penguin »
Had the same thing happen today. Untangle was blocking it.
Eicar-Test-Signature(8fc17bb08a236bdf34b85dca72aea661:109
Weird.
DaN
Post by DaN »
It's because of the eicar.com testvirus:
EFA-Update-3.0.0.7-3.0.0.8.tar.gz/EFA-Update-3.0.0.7-3.0.0.8.tar/Files/Spamassassin-3.4.0a-EFA-Upgrade.tar.gz/Spamassassin-3.4.0a-EFA-Upgrade.tar/Spamassassin-3.4.0-EFA-Upgrade/perl-tar/Mail-ClamAV-0.29.tar.gz/Mail-ClamAV-0.29.tar/Mail-ClamAV-0.29/t/eicarcom2.zip/eicar_com.zip/eicar.com
darky83
Site Admin
Post by darky83 »
Ah..
Good find DaN, would never have taught about that.. :mrgreen:
