I dont see anything that stands out in those 2 logs.
But I am not exactly sure what to look for.
I can't see anything that indicates an error.
This is from the messages logs just before the reboot.
May 27 18:19:16 efagate1 freshclam[33951]: daily.cld updated (version: 20513, sigs: 1397959, f-level: 63, builder: neo)
May 27 18:19:16 efagate1 freshclam[33951]: bytecode.cld is up to date (version: 256, sigs: 45, f-level: 63, builder: dgoddard)
May 27 18:19:19 efagate1 freshclam[33951]: Database updated (3822229 signatures) from db.us.clamav.net (IP: 128.199.133.36)
May 27 18:19:19 efagate1 freshclam[33951]: Clamd successfully notified about the update.
May 27 18:19:19 efagate1 clamd[1637]: Reading databases from /var/clamav
May 27 18:19:30 efagate1 clamd[1637]: Database correctly reloaded (4602389 signatures)
May 27 18:29:30 efagate1 clamd[1637]: SelfCheck: Database status OK.
May 27 18:39:31 efagate1 clamd[1637]: SelfCheck: Database status OK.
May 27 18:49:31 efagate1 clamd[1637]: SelfCheck: Database status OK.
May 27 18:54:22 efagate1 clamd[1637]: Reading databases from /var/clamav
May 27 18:54:34 efagate1 clamd[1637]: Database correctly reloaded (4602365 signatures)
May 27 19:04:34 efagate1 clamd[1637]: SelfCheck: Database status OK.
May 27 19:14:29 efagate1 freshclam[36395]: ClamAV update process started at Wed May 27 19:14:29 2015
May 27 19:14:30 efagate1 freshclam[36395]: Your ClamAV installation is OUTDATED!
May 27 19:14:30 efagate1 freshclam[36395]: Local version: 0.98.4 Recommended version: 0.98.7
May 27 19:14:30 efagate1 freshclam[36395]: DON'T PANIC! Read
http://www.clamav.net/support/faq
May 27 19:14:30 efagate1 freshclam[36395]: main.cld is up to date (version: 55, sigs: 2424225, f-level: 60, builder: neo)
May 27 19:14:30 efagate1 freshclam[36395]: daily.cld is up to date (version: 20513, sigs: 1397959, f-level: 63, builder: neo)
May 27 19:14:30 efagate1 freshclam[36395]: bytecode.cld is up to date (version: 256, sigs: 45, f-level: 63, builder: dgoddard)
May 27 19:14:34 efagate1 clamd[1637]: SelfCheck: Database status OK.
May 27 19:24:34 efagate1 clamd[1637]: SelfCheck: Database status OK.
May 27 19:27:50 efagate1 clamd[1637]: /var/spool/MailScanner/incoming/37258/16666120195.A21A9.message: Sanesecurity.Scam4.782.UNOFFICIAL FOUND
May 27 19:27:55 efagate1 clamd[1637]: /var/spool/MailScanner/incoming/37296/DBBAD1201AF.AC924.message: PhishTank.Phishing.3223335.UNOFFICIAL FOUND
May 27 19:27:56 efagate1 clamd[1637]: /var/spool/MailScanner/incoming/37296/DBBAD1201AF.AC924/nmsg-37296-44.html: PhishTank.Phishing.3223335.UNOFFICIAL FOUND
May 27 19:28:16 efagate1 clamd[1637]: /var/spool/MailScanner/incoming/37465/D0269120225.AD8E6.message: Heuristics.Phishing.Email.SpoofedDomain FOUND
May 27 19:28:17 efagate1 clamd[1637]: /var/spool/MailScanner/incoming/37465/2D2B6120226.ACAF1.message: Heuristics.Phishing.Email.SpoofedDomain FOUND
May 27 19:28:23 efagate1 clamd[1637]: /var/spool/MailScanner/incoming/37510/137CC120248.A1C8F.message: Sanesecurity.Blurl.aed90e.UNOFFICIAL FOUND
May 27 19:28:35 efagate1 init: tty (/dev/tty1) main process (2021) killed by TERM signal
May 27 19:28:35 efagate1 init: tty (/dev/tty2) main process (2023) killed by TERM signal
May 27 19:28:35 efagate1 init: tty (/dev/tty3) main process (2025) killed by TERM signal
May 27 19:28:35 efagate1 init: tty (/dev/tty4) main process (2027) killed by TERM signal
