Emailaddress used to release mail
Posted: 27 May 2015 18:58
by Mr. Happy
I just tried to release a mail to an external mailaddress.
The logging said it could not be delivered, because the domain doesn't exist (correct 'cause the sending emailaddress is my internal domain).
Where do I change it to my external domainname? (Or is that a definite no-no?)
Re: Emailaddress used to release mail
Posted: 28 May 2015 20:34
You could add an entry into /etc/hosts to get around this, I believe. :D
Posted: 08 Jun 2015 06:34
by Mr. Happy
I could, but that would not solve the issue...
The external domain can't do a nslookup of my internal domain...
Posted: 08 Jun 2015 08:21
by darky83
If you release an message the default 'from' is used so i'm guessing here that your from adres in the mail is wrong?
I never tried it but you could try to edit the source email, first you need the ID of the message you can see the ID in MailWatch it is in the format of xxxxxxxxxx.xxxxx
Then use the first part of the ID and search for the local file:
find /var/spool/MailScanner/quarantine/ -name *E24D1120FBA* -print
Edit the file it has found so the correct 'FROM' is used and try to re-release the message.
Ofcourse a better aproach would be to use the correct sending domain for all your mails :)
Posted: 08 Jun 2015 08:38
by Mr. Happy
Sending mail to external smtp works fine, except when I try to release from quarantine to an external smtp server.
Then it fails (cause it using postmaster@<internaldomain.lan>.
Posted: 08 Jun 2015 08:45
by darky83
Ah, misunderstood that.
login with SSH and in the menu choose "IP settings"
Then change the domain name to your external domain.
Posted: 08 Jun 2015 09:02
by Mr. Happy
thanks!
