Logjam Vulnerability
Starting a thread on the Logjam Vulnerability.
I am currently researching and will post results and how-to here. :ugeek:
Re: Logjam Vulnerability
Apache already has DH 2048bit and export ciphers disabled. No action needed here. Apache is not vulnerable in EFA to logjam
Postfix is vulnerable.
To fix weak DH key:
Generate a 2048bit Diffie-Hellman key
sudo openssl dhparam -out /etc/postfix/ssl/dhparam.pem 2048
Add the DH key to postfix:
sudo postconf -e "smtpd_tls_dh1024_param_file = /etc/postfix/ssl/dhparam.pem"
More info located here:
http://postfix.1071664.n5.nabble.com/Di ... 63096.html
To disable export ciphers:
sudo postconf -e "smtpd_tls_ciphers = low"
sudo service postfix reload
