Our quarantine reports havent been sending for the last 10 days or so, nothing has been changed on the config of the EFA filter.
Where should I start to look to fix this?
If I run the command manually the reports are sent successfully.
sudo /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php
quarantine reports have stopped sending
- Socal_Steve
