Update-Behaviour
Posted: 28 Mar 2015 09:18
by SPQRInc
I would like to ask, if it is possible to use the yum-update on efa without crashing the software.
And: If I do auto-updates (Efa) - are custom changes on postfix's main.cf overwritten?
Thanks and have a nice weekend :-)
Re: Update-Behaviour
Posted: 29 Mar 2015 01:08
If you run yum update...here's the safer method...
yum --exclude="kernel* mysql* postfix* mailscanner* clamav* clamd*" update
Auto updates should leave main.cf intact as it uses the above yum update as well.
Posted: 30 Mar 2015 03:06
added to the wiki
Posted: 30 Mar 2015 03:38
by mitgib
shawniverson wrote:If you run yum update...here's the safer method...
Even safer would be to edit /etc/yum.conf and add the following
exclude=kernel* mysql* postfix* mailscanner* clamav* clamd*
This way you are not fumbling for the wiki page on every update, but why would you not update the kernel? Unless you are also using ksplice or kernelcare or one of the other kernel patching services.
Posted: 30 Mar 2015 11:11
Adding this to yum.conf will cause problems down the road when these packages are actually targeted for update.
Also, kernel is excluded because many EFA users run on VMware, and vmware-tools or open-vmtools must be recompiled after every kernel update.
Posted: 23 Sep 2015 07:25
by ZimboKraut
Hi there,
would it be safe to say, that if you are running on hardware, or possibly KVM, it would be safe to update the kernel?
Posted: 23 Sep 2015 16:38
by darky83
It should be, I run a few systems on bare hardware and did a number of kernel upgrades without issue.
As you run it on bare hardware and/or in KVM I assume you have enough knowledge to fix possible issues.
Except VMware tools there are no items in EFA that require an specific kernel version.
