Improving my EFA Performance
toddh
Post by toddh »
I am wondering if there is something amiss with my EFA box or this is normal. I have been adjusting hardware and setting trying to improve speed/performance. Not in accuracy but rather how many messages EFA can handle per min/hr.
We processed 23588 messages yesterday total.
Yesterday morning the inbound queue started to back up. My config at the time was 8 Cores, 8 Gb Ram, 8 Mailscanner threads.
Load was showing just under 3 across the board, ie 2.83, 2.78, 2.88. MailScanner threads showed 11.
I though the load should be higher with 8 cores. I changed the MailScanner threads from 8 to 10 and load went to just under 8, ie 7.89, 7.83, 7.66 and MS Threads went to 18. The queue came down within 15 min.
Still new to EFA so trying to get a handle on performance and loading.
Why did it back up? 8 Cores, 8Gb and 8 MS Threads seems like it should handle this volume? And why with 8 MS Threads was it only loading the CPU at less than 3?
Not sure why all the Processing came down and CPU resources went up so significantly when I changed the MS Threads from 8 to 10?
Todd
Re: Improving my EFA Performance
I'd say something is wrong. That's just way too high.
run top, display all the CPUs.
Is the machine running out of memory and swapping?
Is the machine stuck with a high % of IOWAIT? (waiting on disk io)
Which process is getting hung up and consuming cpu?
Without more information, it's very difficult to say.
With 8 cores, you may want to try around 16 mailscanner threads.
EFA-Configure has a limit of 10, so edit /etc/MailScanner/MailScanner.conf and change it there.
darky83
Site Admin
Post by darky83 »
One overlooked item can sometimes be disk IO do you see any issues there on the VM hosts?
If you look at top also try to see if there is any wait time, it should be close to 0, if higher your system is waiting for something and in most cases its disk IO.
top - 21:14:22 up 39 days, 1:12, 1 user, load average: 0.62, 0.55, 0.58
Tasks: 156 total, 2 running, 154 sleeping, 0 stopped, 0 zombie
%Cpu(s): 5.6 us, 2.0 sy, 0.0 ni, 87.0 id, 0.1 wa, 0.0 hi, 2.3 si, 0.0 st
toddh
Post by toddh »
Is the VM running out of Memory and swapping - I don't think so. I started with 2 Gb Ram and have been slowly incrementing by 2GB so now I am up to 8 Gb. So far whatever I give it seems to use. However when the slowness occurred several days ago I bumped ram from 6 to 8 Gb and it made no difference. Adding cores at the time did.
Top processes rotate but mostly MailScanner, Clam, ImageCerbius, and MySQL. I would like to move the MySQL DBs to a dedicated MySQL server we have and offload some resources.
Top after its been running about 35 hrs
EFA1 Top.PNG (51.83 KiB) Viewed 37654 times
I am seeing wa times from .0 - 12.% at the moment, which is a slower time right now - 5 pm and everyone is leaving for the day. I will look at my disks and see where this VM is running. Its on a cluster so I have to trace the CSV to the SAN and Disk Volume.
Press '1' in top to give a per CPU usage breakdown and send a screenshot of that.
Next, try iotop and get a feel of what is happening with io and how much
How did you setup your system? By hand, or from the prepared vm images?
What about the host machine? Is it busy, or lacking ram?
As a wild ass guess, I'd suspect mysql being the bottleneck to mailscanner.
Perhaps there is a way to debug the time it takes for Mailscanner to handle requests. That information could give you a better indication of where Mailscanner is being held up. Once you know that, then solving the problem becomes much easier.
Hmmm...
Interesting. I am getting slower performance now. I am seeing a lot of iowait.
Let me see if I can figure this out...
Re: Improving my EFA Performance - findings
SA Learn causes a lot of IO wait for me
toddh
Post by toddh »
VM is vhd from EFA.
Morning business is starting here so this is normal/light load
EFA1 Top1A.PNG (71.68 KiB) Viewed 37644 times
Host machine has nothing else significant running. Dell c6100, 2x Xeon L5520( 16 Cores ) 48 Gb ram. The SAN and disk array that the VM sits on runs a number of other VMs so the storage is not idea for this type of load. I enabled LSI Cachecade on the CSV last night to see if that helps.
It looks like the mailscanner process is getting hung up on i/o somewhere.
I have an idea. I'll test it in a couple of hours and let you know if it makes a difference for me.
toddh
Post by toddh »
I think part of my confusion at the high load is that we were previously using a similar box, Postfix, SA, Clam, and it processed the same load on 8 year old hardware with only a fraction of the load. Ran single CPU with 2 or 4 cores and 4gb of ram, averaged around 15% cpu and rarely used 2gb with 20 Amavis/SA processes running.
Was a project called Maia Mailguard and it off loaded everything to a MySQL server. All SA config, Spam and Ham as well as Bayes were kept in MySQL db which we ran on a separate server.
I know things change so I was trying to get a feel for if this is normal in EFA or is there something off with my system. And if there was a way to improve performance without adding more resources.
It should be plenty of hardware, that's not the problem. The problem is elsewhere.
I'm doing some testing now to see if I can isolate the issue.
I am curious toddh. If you halt mail flow to your appliance, does your CPU trend down to idle? Or does it still show a high load (especially MailScanner)
Even with the amount of mail you are processing, I agree with pdwalker that something may be amiss.
Also, I would be particularly interested in whether you have your Maximum Processing Attempts in MailScanner set to a non-zero value.
Shawn, I expect if he does as you say, the load will drop to near 0.
I'm now almost certain that the problem is because of an unoptimal mysql configuration. I'm playing with the configurations now to see if I can improve the performance without making too many changes.
todd,
Do you get a lot of non English language mail into your system?
toddh
Post by toddh »
If I remove mail does cpu to to 0. Yes. It drops in the evenings to a load of .3 or so. I also have a 2nd EFA, clone of this VM, that runs as 2nd MX and processed only 400 messages today, load is 0, 0, 0.
Do we get a lot of non English? I would say a few but not a lot. Probably a relatively small percentage.
The Cerbius Image plugin seems to use a lot of cpu when it kicks in, anywhere from 100 - 350%.
Appreciate the help!
toddh
Post by toddh »
Shawn,
Maximum Processing Attempts is set to 0
Can you run the following command a couple of times and tell me what kind of queries to which database you are seeing?
mysqladmin -uroot -p<EFA mysql root password from /etc/EFA-Config> processlist
run it 5 or 10 times. what ones in the "db" column show active queries? ("Command" column = "Query")
The output will appear something like
| Id  | User      | Host      | db          | Command | Time | State         | Info        |
| 3   | mailwatch | localhost | mailscanner | Sleep   | 269  |               |        |
| 7   | sqlgrey   | localhost | sqlgrey     | Sleep   | 1592 |               |        |
| 26  | root      | localhost |             | Sleep   | 0    |               |        |
| 53  | root      | localhost | sa_bayes    | Sleep   | 797  |               |        |
| 111 | mailwatch | localhost | mailscanner | Sleep   | 38   |               |        |
| 445 | sa_user   | localhost | sa_bayes    | Query   | 0    | freeing items | UPDATE bayes_token
                     SET spam_count = spam_count + '1'
                   WHERE i |
| 448 | root      | localhost |             | Query   | 0    |               | show processlist        |
What I see on my system is a lot of is a large number of quick queries happening to the sa_bayes table (I use the spam/ham training for a few messages in the Message Operations page)
toddh
Post by toddh »
Went to look for the pw in /etc/EFA-Conf and found
INTERFACE:eth0
But I am using eth1.
I get this error when booting. Could this be related
EFA eth0 error.PNG (50.05 KiB) Viewed 37629 times
I believe this happened after I moved or copied the VM, not sure which. I simply assigned IP info to eth1 when it happened and everything was working so I left it.
toddh
Post by toddh »
MySQL query. Ran it a number of times, most responses were like the last 2.
First, edit your post and remove the password.
What was the load average during that time? And was top showing iowait during that time?
If so, we're both experiencing the same thing.
I'm still looking.
toddh
Post by toddh »
When I run the command a number of times quickly i get the f0llowig. Not much change in Top. Load was around 2.17, 1.79, 1.58, not a large variance.
EFA MySQL Query1.PNG (41.23 KiB) Viewed 37601 times
You're seeing the same thing I am.
While the system is running sa-learn, the rest of the system grinds to a halt, or becomes very slow and unresponsive. It is like the whole system waits until sa-learn completes. It seems to take about 30 seconds per message for sa-learn to run.
It's not an SQL table lock contention as I get the same performance when using InnoDB tables as I do with MyISAM tables. I get no slow queries (slow queries longer than 1 second in my configuration). Also, the sa-learn sends hundreds of update queries for that time. My database goes from 0qps to over 100qps.
Also, the UI blocks while sa-learn is running, which it shouldn't do.
The databases are tiny, and should be running out of cache in my configuration.
It's puzzling.
This seems way too high.
Timed mine a 6 sec/message.
