Spam Blacklist shared
woundride
Post by woundride »
If you are interested, even if it's more for french users, I share a blacklist that I update daily.
http://spam.woundride.com
You can use directly in your EFA appliance.
I've created a little script using massimport.sh script to synchronize your blacklist database with my file.
You can download the package :
[root@efa opt]# wget http://www.woundride.com/spam/update_efa.tar.gz
And use simply :
[root@efa opt]# sh update_spam_blacklist_woundride.sh
----------Downloading blacklist file----------
--2015-03-26 13:31:06--  http://www.woundride.com/spam/spam_blacklist_by_woundride.txt
Resolving www.woundride.com... 217.70.180.132, 2001:4b98:dc0:950::132
Connecting to www.woundride.com|217.70.180.132|:80... connected.
Length: unspecified [text/plain]
Remote file is newer, retrieving.
Saving to: 'spam_blacklist_by_woundride.txt'
    [  <=>                                  ] 82,061       208K/s   in 0.4s
2015-03-26 13:31:06 (208 KB/s) - âspam_blacklist_by_woundride.txtâ
----------Updating EFA blacklist database----------
----------Restart MailScanner Service----------
Shutting down MailScanner daemons:
         MailScanner:                                      [  OK  ]
         incoming postfix:                                 [  OK  ]
         outgoing postfix:                                 [  OK  ]
Waiting for MailScanner to die gracefully ... dead.
Starting MailScanner daemons:
         MailScanner:                                      [  OK  ]
Sincerelly.
Charles.
Re: Spam Blacklist shared
Charles,
How do sites get onto your list?
woundride
Post by woundride »
Hi pdwalker,
I've add the senders manually, when I've received spam, phishing, newsletters...
I enriched this list for years.
You can see the list here : http://spam.woundride.com
Sincerelly.
Charles.
mitgib
Post by mitgib »
Charles,
This was a great start to populate a blacklist, but as a ISP, facebookmail.com had to go ;) When I saw the Black lines on NASCAR emails from facebook, I know it would start my support guys a major headack, then sendgrid.net was being used by a vendor I actual do business will, so had to remove that as well.
So anyone grabbing this list, you'll find it is a major help, but review what it hits on, you may want it.
Tim
cyril.lebert
Post by cyril.lebert »
Bonjour Charles
Ton fichier est il a jour ? Est ce cela efface ma liste ?
Merci
cyril.lebert
Bonjour Charles,
Je viens de mettre ta liste, effectivement y a du monde ;)
Merci
Cyril
P.S: Cette lise est mise à jour régulièrement ? / Est-il possible de l'editer manuellement ?
mortimer
Post by mortimer »
fonctionne à merveille
Merci du partage :clap:
infos :http://www.woundride.com/spam/utilisation_avec_efa.php
