Blacklist comlete email address
woundride
Post by woundride »
I've blacklisted many domains, it's OK, but can you answer to me, is it possible to blacklist complete email address ?
So I've tested to add a personnal email address type myaddress@gmail.com, but, when I sent a message, EFA does not block my message...
By advance, thank you.
Sincerelly.
Charles.
darky83
Site Admin
Re: Blacklist comlete email address
Post by darky83 »
on the WebGui add it under lists as:
to: default @
List: Blacklist
Make sure to keep the second field for the 'to' address empty.
if you want it to activate right after adding (for testing) then reload mailscanner
service mailscanner reload
woundride
Post by woundride »
Hi darky83,
Thank you for your answer ;)
I've tested to add on Web Gui as you said and I've relaod, end even restart MailScanner service, the message is tagged "blacklisted" in the Web Gui, but I receive the message :
Sincerelly.
Charles.
woundride
Post by woundride »
Now have the same problem with some domain names... :think:
The message is tagged {Spam?} and received in the mail box, so is indicated in blacklist.
Can do we adjust the cleanup in MailScanner.conf with option "Spam Action" ?
Sincerelly.
Charles.
woundride
Post by woundride »
I've found solution, in MailScanner.conf I've add :
High Scoring Spam Actions = delete
It's OK.
Sincerelly.
Charles.
This is a MailScanner configuration problem. MailScanner "blacklists" emails by marking them as spam in its engine. If the spam action is set to deliver, it will still be delivered.
What does your "Spam Actions" and "High Spam Actions" have set?
woundride
Post by woundride »
Hi shawniverson,
First, I kept default configuration :
Spam Actions = store custom(spam)
And no High Scoring Spam Actions.
I've see the file :
/usr/lib/MailScanner/MailScanner/CustomFunctions/CustomAction.pm
But it's not easy for me to configure with this file...
So, in MailScanner.conf, I kept :
Definite Spam Is High Scoring = yes
And I've add :
Sincerelly.
Charles.
