Spam getting through even if it has been marked as spam
tentaclefi
Re: Spam getting through even if it has been marked as spam
Post by tentaclefi »
This is the output.
[root@mailscanner-in ~]# spamassassin -D --lint 2>&1 | grep bayes:
Mar 13 03:06:14.228 [15197] dbg: bayes: learner_new self=Mail::SpamAssassin::Plugin::Bayes=HASH(0x54ce4c8), bayes_store_module=Mail::SpamAssassin::BayesStore::DBM
Mar 13 03:06:14.236 [15197] dbg: bayes: learner_new: got store=Mail::SpamAssassin::BayesStore::DBM=HASH(0x61e6828)
Mar 13 03:06:14.236 [15197] dbg: bayes: no dbs present, cannot tie DB R/O: /root/.spamassassin/bayes_toks
Mar 13 03:06:14.241 [15197] dbg: bayes: no dbs present, cannot tie DB R/O: /root/.spamassassin/bayes_toks
There's rule hits though.
Maillog doesn't give me any hints of bayes :(
Screenshot 2020-03-13 at 9.09.04.png (469.25 KiB) Viewed 6113 times
Just google on the error message.
Must be something like this.
Mar 13 09:38:04.667 [26178] dbg: config: fixed relative path: /var/lib/spamassassin/3.004004/updates_spamassassin_org/23_bayes.cf
Mar 13 09:38:04.668 [26178] dbg: config: using "/var/lib/spamassassin/3.004004/updates_spamassassin_org/23_bayes.cf" for included file
Mar 13 09:38:04.668 [26178] dbg: config: read file /var/lib/spamassassin/3.004004/updates_spamassassin_org/23_bayes.cf
Mar 13 09:38:05.520 [26178] dbg: bayes: learner_new self=Mail::SpamAssassin::Plugin::Bayes=HASH(0x5953aa0), bayes_store_module=Mail::SpamAssassin::BayesStore::SQL
Mar 13 09:38:05.529 [26178] dbg: bayes: using username: postfix
Mar 13 09:38:05.529 [26178] dbg: bayes: learner_new: got store=Mail::SpamAssassin::BayesStore::SQL=HASH(0x609ac20)
Mar 13 09:38:05.544 [26178] dbg: bayes: database connection established
Mar 13 09:38:05.545 [26178] dbg: bayes: found bayes db version 3
Mar 13 09:38:05.545 [26178] dbg: bayes: Using userid: 3
Mar 13 09:38:05.590 [26178] dbg: bayes: corpus size: nspam = 23260, nham = 14087
Mar 13 09:38:05.592 [26178] dbg: bayes: tokenized body: 120 tokens
Mar 13 09:38:05.592 [26178] dbg: bayes: tokenized uri: 0 tokens
Mar 13 09:38:05.592 [26178] dbg: bayes: tokenized invisible: 0 tokens
Mar 13 09:38:05.593 [26178] dbg: bayes: tokenized header: 14 tokens
Mar 13 09:38:05.594 [26178] dbg: bayes: tok_get_all: token count: 20
Mar 13 09:38:05.595 [26178] dbg: bayes: score = 0.512017780185575
Mar 13 09:38:05.597 [26178] dbg: bayes: DB expiry: tokens in DB: 149728, Expiry max size: 150000, Oldest atime: 1560712202, Newest atime: 1584088685, Last expire: 1582827919, Current time: 1584088685
Mar 13 09:38:06.025 [26178] dbg: timing: total 1747 ms - init: 1273 (72.8%), b_tie_ro: 16 (0.9%), parse: 1.10 (0.1%), extract_message_metadata: 5 (0.3%), get_uri_detail_list: 2.7 (0.2%), tests_pri_-1000: 9 (0.5%), compile_gen: 152 (8.7%), compile_eval: 28 (1.6%), tests_pri_-950: 7 (0.4%), tests_pri_-900: 7 (0.4%), tests_pri_-100: 16 (0.9%), check_bayes: 9 (0.5%), b_tokenize: 3.4 (0.2%), b_tok_get_all: 0.74 (0.0%), b_comp_prob: 0.23 (0.0%), b_tok_touch_all: 1.60 (0.1%), b_finish: 1.53 (0.1%), tests_pri_-90: 9 (0.5%), tests_pri_0: 298 (17.1%), tests_pri_10: 7 (0.4%), tests_pri_20: 7 (0.4%), tests_pri_30: 7 (0.4%), tests_pri_500: 89 (5.1%), tests_pri_1000: 7 (0.4%)
vondess
Post by vondess »
It sometimes happens with me as well. Spam mails are getting through the filter without any proper reason for it. Does anybody know what can cause it? And how to eliminate it? I would need to know what additional actions I should take. I am from https://postcodefinder.net/england/ location. Is there anybody from my area here to have a look at my settings? Thanks a lot.
tentaclefi
I just reinstalled the appliance (4.0.2) from scratch and it has been working well ever since.
Not like a real solution but saved endless hours of googling around :)
