We do not use VMWare, we run XenServer!
Best way to backup and restore?
Re: Best way to backup and restore?
If I type  it says bash: sudo:: command not found
sudo /usr/local/sbin/EFA-Backup -backup- shawniverson
No sudo?
Try running as root instead without using sudo
Found out that EFA-Backup was not executable. It is working now.
Does any one have steps on how to do this on EFA 4.0.,4 ? I can't seem to find EFA-Backup or EFA-Configure under/usr/local/sbin
[root@efa4 sbin]# ls -l /usr/sbin/eFa*
-rwxr-xr-x  1 root root  7450 Feb 26 12:12 /usr/sbin/eFa-Backup-cron
-rwxr-xr-x  1 root root 11036 Mar 13 01:36 /usr/sbin/eFa-Configure
-rwxr-xr-x  1 root root  2060 Feb 26 12:12 /usr/sbin/eFa-Daily-DMARC
-rwxr-xr-x  1 root root  5019 Feb 26 12:12 /usr/sbin/eFa-Monitor-cron
-rwxr-xr-x. 1 root root  8509 Feb  3  2020 /usr/sbin/eFa-Post-Init
-rwxr-xr-x  1 root root  1736 Feb 26 12:12 /usr/sbin/eFa-Weekly-DMARC
This capability is often present in backup systems. Due to the various external and internal threats to information systems and data, make sure data is complete and unaltered during the backup process.
