Just deployed a fresh EFA install at a site today. All latest updates, etc. Working fine, but two small issues.
1. I am unable to logout from ssh. Option "0" just goes straight back to the menu.
2. Browsing to http://yourefaserver/ just gives a blank page. Browsing to http://yourefaserver/mailscanner/status.php brings up the login okay.
Stuart
Logout from ssh and Mailwatch access
Re: Logout from ssh and Mailwatch access
without logging into your system, it'd be hard to diagnose for me regarding your logout problem.
For your webpage problem, go to /var/www/html/ directory and look for index.html. It should look like this:
which basically says, "refresh to the page at /mailscanner/"
<!DOCTYPE html>
<html>
<head>
<title>MailWatch</title>
<meta http-equiv="refresh" content="0; url=/mailscanner/" />
</head>
<body>
</body>
</html>
I know it has been a month, but they are not big issues and not worth trying to resolve.
The logout problem is not a big deal. I just use option 1 to get to the command line, and then "logout".
The webpage problem only seems to happen from one computer. I'm guessing the meta refresh is being blocked.
