Well the last upgrade crashed out to the point I decided to download and install from scratch the latest VMware OVA of eFa to replace the old one.
I went through and made all the same changes to the config.php as before from: viewtopic.php?f=14&t=1484.
Made changes to mailwatch_ldap_sync.sh that I found in the new path of /usr/local/bin/mailwatch/tools/LDAP/ to match.
Made sure I installed php-ldap (yum install php-ldap)
Made sure I installed the openldap-clients (yum install openldap-clients)
I ran the script above and my database populated properly.
But when I make the last change to conf.php of
define('USE_LDAP', true);I receive:
Forbidden
You don't have permission to access /mailscanner/checklogin.php on this server.
Additionally, a 403 Forbidden error was encountered while trying to use the ErrorDocument to handle the request.
If I change the setting back to
define('USE_LDAP', false);For those I get:
Bad Username or Password
Any ideas?
Thanks, Jeff
