Quarantine Report
b19wll
Quarantine Report
Post by b19wll »
Hello
I have edited the report so it only lists 1 day(s) worth of spam. I have also edited the quranatine_report.php so it only lists spam and not legit emails. Since doing this I am no longer getting the daily report :(
I have looked under cron jobs and cant see the command that would trigger the report, I wanted to try running it manually to see if I could spot what the problem was.
Can anyone help?
Will
Re: Quarantine Report
You have a typo most likely somewhere in your quarantine_report.php
b19wll
Post by b19wll »
This is what I have edited in that file
AND
 a.date >= DATE_SUB(CURRENT_DATE(), INTERVAL ".QUARANTINE_REPORT_DAYS." DAY)
AND
 a.isspam>0
ORDER BY a.date DESC, a.time DESC";
I have not changed anything else in the file?
b19wll
Post by b19wll »
It might be connected, but I have also just noticed that the inline signatures are no longer being stamped on the emails?
hmmm...it looks okay.
Run it and see what happens...as root
sudo /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php
Also, do me a favor and run through EFA-Configure and double check your spam settings are set the way you want them.
b19wll
Post by b19wll »
Hello
This is what I get when I run that command
[admin@tower4 ~]$ sudo /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php: line 3: ?php: No such file or directory
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php: line 5: /bin: is a directory
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php: line 6: MailWatch: command not found
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php: line 7: syntax error near unexpected token `C'
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php: line 7: ` Copyright (C) 2003  Steve Freegard (smf@f2s.com)'
Also When I run EFA-Configure I get command not found?
Will
Yep you have problems with your quarantine_report.php
Your file should start with the following lines.
#!/usr/bin/php -q
<?php
 MailWatch for MailScanner
For EFA-Configure:
sudo /usr/local/sbin/EFA-Configure
b19wll
Post by b19wll »
Great that's fixed one of the problems :)
I had a blank line above #!/usr......
#!/usr/bin/php -q
<?php
I will look at the EFA-Configure now
Will
b19wll
Post by b19wll »
After running through EFA-Configure again my inline sigs are now working again.
Thanks for your help.
One more quick question, what is the trigger for /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php to be ran?
Will
/etc/cron.daily/mailwatch
:whistle:
b19wll
Post by b19wll »
Good news, the quarantine report was sent early this morning at 04:00am and then again at 04:01am and 04:02am and every minute upto 04:59am
Please help?
Will
b19wll
Post by b19wll »
I hope I have found the problem
the cron job was set to run as below
Mins = All
Hours = 4
Days = All
Months = all
Weekdays = All
I have now changed the Mins to = 0
Will wait and see what happens tomorrow morning.
Will
colin
Post by colin »
I only ever want to see spam in the quarantine report. Why would you want to see non-spam?
I also change the report to only include the last day only by editing /var/www/html/mailscanner/conf.php as follows:
change
define(QUARANTINE_REPORT_DAYS, 7);
to
define(QUARANTINE_REPORT_DAYS, 1);
Would it be possible to have this as a default? I can see no reason why you would want to be told day after day what the last seven days contained.
Colin
Yep this is coming in the next update.
:mrgreen:
Socal_Steve
Post by Socal_Steve »
colin wrote:I only ever want to see spam in the quarantine report. Why would you want to see non-spam?
change
to
Colin
How did you change the report to only show spam? much appreciated. never mind fixed it see below
STEVE
Socal_Steve
b19wll wrote:This is what I have edited in that file
AND
AND
 a.isspam>0
The
AND
 a.isspam>0
worked for me to make the report only show spam.
