Font issue after upgrade to 3.0.1.9
Re: Font issue after upgrade to 3.0.1.9
Ok,
I've changed my mind slightly. I don't think I can call it an actual mailwatch bug. The full explanation is at the above "bug" report link.
The solution? Edit your viewmail.php file and change following line
$v = htmlentities($v);
to
$v = htmlentities($v,ENT_NOQUOTES,"utf-8"));
It's around line 139.
Otherwise, don't worry about it. It's really a minor problem.
Ramas
Post by Ramas »
Thanks for your great work.
I read your monolog in MailWatch github ;)
Thanks for suggested fix, tried - it works.
Ramas
