EFA Development
buzzzo
EFA Development
Post by buzzzo »
What is your policy regarding the development of EFA, in particular related to Mailwatch ?
I've made some small addition to the code and would like to know:
1) Do you mantain your own "forked" copy of mailwatch of update from upstream whenever the code is updated ?
2) Do you accept addition ?
Thx in advance
darky83
Site Admin
Re: EFA Development
Post by darky83 »
E.F.A. combines existing products it does not maintain any of the used products.
If you have any improvements I would suggest that you send those to the mailwatch project:
https://github.com/mailwatch/1.2.0
If they are implemented there, eventually they will be used in E.F.A. also.
