test 4/7 attaches a batch file called "attached%2E" which decodes to "attached." That file cannot be run unless it is renamed to "attached.bat", so I would ignore that one.
test 5/7 attaches a batch file called "ATT00001.dll" and should be blocked, so I'd consider this a legitimate fail.
test 6/7 attaches a batch file called "attached.()bat". The extension ".()bat" won't run on a windows computer, so I wouldn't consider that a fail. You can ignore this.
test 7/7 attaches a batch file called "attached" As it has no extension, Windows won't run it. Not a legitimate fail. Ignore.
[root@gw omer]# nano /etc/MailScanner/filename.rules.conf
[root@gw omer]# /etc/init.d/mailscanner restart
Restarting MailScanner ...
Possible syntax error on line 140 of /etc/MailScanner/filename.rules.conf at /usr/share/MailScanner/perl/MailScanner/Config.pm line 1672
Remember to separate fields with tab characters! at /usr/share/MailScanner/perl/MailScanner/Config.pm line 1674
MailScanner restarted with process id 14923
