After upgrading, when I try to access the mailscanner webpage I get:
The following conf.php mandatory entries are missing, check and compare your conf.php with conf.php.example.
- LDAP_SSL
I then added "defile ('LDAP_SSL' true);" to /var/www/html/mailscanner/conf.php
and now get:
Forbidden
You don't have permission to access /mailscanner/status.php on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Upgrade 3.0.1.9 - Cannot access web page
Re: Upgrade 3.0.1.9 - Cannot access web page
Need a comma..
define('LDAP_SSL', true);Re: Upgrade 3.0.1.9 - Cannot access web page
Thanks, fixed the typo but still getting the same error.
Look at your apache error logs and refresh the page, see what you are getting as an error...in /var/log/httpd/
Thanks, that pointed me back to the same line in conf.php There was another typo. defile instead of define. A Freudian slip that did exactly what I typed
I just need to get LDAP working again now, but that is something I can play with.
